wareagle wrote:well from those, the top showed me somthing i didnt know. randy jumped his amps. you can see the 2 chords.
Yep, instead of jumping channels he jumped his amps and went from the right to the left. That's one of the advantages when using 4-holer amps you can link as much amps together as you want!
wareagle wrote:the bottom one, the 2 on the left are the light up switches and the left one looks to be a preamp one
I think the preamp one was the 'small logo toggle switch' head and was placed behind the stacks. I think it was always there, sometimes it was stacked upon the white amp and sometimes behind the stacks I guess. Again: just speculating, but for sure he did use 4 heads in '81 and '82.
Yes it does look strange, I heard that '76 was a transition year where they tried all kind of weird combinations, bigger logo's, small logo's, rocker switches but also toggle switches. About the channel numbering: the reissue SLP's now have the 1 1 2 2 numbers, but the handwired 1959HW for instance have the I I II II.wareagle wrote:that amp looks strange, the middle pic, it had inputs bolded and 1 1 2 2 instead of I I II II which i havent seen on a 76 model.
Marshall said that the white amp had EL34 (6ca7 type) tubes. (Groove tubes) And no information about the other amps......wareagle wrote:in avoidance of strting a new thread any 1 know what tubes he used?
So I expect that big bottle EL34's are in the new 1959RR as well? (no problem if you did start a new topic btw
