My Life
My Life
Hey, I just wanted to vent for a minute about my life situation. It seems that every time I start to get things back on track, life throws me a curve ball.
This is what I wrote in my blog on myspace:
"So, I've been doing my best to work on my music studies. I found a couple of really good theory books recently - Theory for the Contemporary Guitarist by Guy Capuzzo and Fingerboard Theory for Guitar by Mike Christiansen. They both have excellent information about how music works from the point of view of a guitar player. They explain intervals and construction of both scales and chords. They explain the relationships between scales and chords. And most importantly for me, they both explain how to learn to read music and apply it to the guitar. Needless to say I've been really enjoying studying these books, because I finally have the key to "putting it all together". I've had the scales and chords down for ages but could never combine everything in a sensible manner before. Now it is making sense and I am able to apply the knowledge right away.
Unfortunately (there's always an "unfortunately" for me), I suffered a physical set back this week. On Tuesday night I was reading in bed when I heard my sons fussing in the other room. I went to get up to go talk to them when I got a sharp, debilitating pain in my neck. It was so bad that it radiated down my right arm, making it go numb and rendering it useless. In addition, the pain radiated down my back adding to the difficulties I already have there.
So, I went to the doctor yesterday to seek relief. The MRI shows "degeneration of the cervical discs," according to the doc. So she prescribed a muscle relaxent and pain killers and told me to go back to my neurologist. I will see him on January 30th.
When I got home, I looked up disc degeneration and found a definition at http://www.necksurgery.com. Apparently degenerative disc disease (DDD) is when intervertebral discs lose their flexibility, elasticity, and shock absorbing characteristics. The ligaments that surround the disc become brittle and they are more easily torn. At the same time, the soft gel-like center of the disc starts to dry out and shrink. It can become painful and cause several different symptoms, including neck pain, nerve root issues, and spinal cord compression. This is caused by the fact that worn out discs are a source of pain because they do not function as well as they once did, and as they shrink, the space available for the nerve roots and the spinal cord also shrinks. As the discs between the intervertebral bodies start to wear out, the entire cervical spine becomes less flexible.
The common symptoms that suggest that degenerative disc disease may be responsible for a person's pain include neck pain, pain that radiates down to the back of the shoulder blades or into the arms, numbness and tingling, and sometimes even difficulties with hand dexterity or walking. Muscle weakness occurs at a later stage in the degenerative process than pain does, and it is a sign that disease is relatively more serious. In severe cases of cervical DDD, where there is evidence of spinal cord compression, individuals may experience symptoms of sciatica and back pain, and lower extremity weakness.
As it turns out, I have all of these symptoms. Which might explain why I have not been able to recover from my back pain after the surgeries I've already had. It will be interesting to see what my neurologist says at the end of the month. He's also going to do some electrical stimulation tests to determine how bad the situation is currently and what migh be done to rectify the situation. From what I have read, medication is used to reduce inflamation in some situations, while in other, more serious situations, surgery is required to relieve pressure on the nerves. There is a possibility of fusing the vertebrae and putting in a plate in some instances.
The good news is, if the degeneration and nerve damage isn't too bad, I could be well on my way to recovery 3 months after surgery. If an operation can remove my pain, I would be a very happy man.
So, for now it's time to wait and see - and deal with a bit more pain."
Thanks for letting me vent, I think I need some vicodin :shock:
:shock: Jeez!!! RR that sounds bad, I hope you can get through this. I hate hospitals and medication but if I was suffering like you are I would take my chances under the knife.
I really hope that it goes well and although we have clashed in the past.... on this site you are a friend, as a friend I wish you the very best :) .
PS, what did cause the comotion in your sons room?
Trigger wrote:PS, what did cause the comotion in your sons room?
You know, I never did find out. I struggled to stand up, then I fell and next thing I know, both of my boys were standing by me trying to help. My 2-year-old kept saying, "Get up dad, get up." :D
If I were to guess, I'd say the younger son wanted to play "Hide from the Aliens" (a game they made up as an excuse to climb into cupboards and things) and the older son wanted to play video games instead. That's the usual fight between them.
frank
Student & Friend of Randy
Post by frank »
get those suckers fused and be done with it, paul. you need to come out and play.
Sarab
Post by Sarab »
frank wrote:get those suckers fused and be done with it, paul. you need to come out and play.
Agreed. come out and play with us!!!
The more I read about it, the more I am hopeful that surgery will finally end the pain. I'm keeping my fingers crossed!
frank
Post by frank »
this is going to be a better year for me and i'm believing the same for you paul.
frank wrote:this is going to be a better year for me and i'm believing the same for you paul.
Thank you, Frank. Your encouragement means a lot. I've got to say, ever since I found out about the possibulity of a healing surgery, my spirits have been much better.
frank
Post by frank »
good to hear that paul. perspective is so important in every way.
Mick Mars
Post by RR-ElectricAngel »
Paul, hope everything smooths out for you in the near future. I remember hearing what Mick Mars went through just to tour with Motley Crue. I will never complain of back pain again...
