Now then, maybe this time Matt won't delete this!
When I play it, I add a fourth lower on the root note to give it that extra depth. I also use a bit of chorus (Width at 3 O' Clock, rate at 9 O' Clock.) to give it even more depth.
It helps to add mids to it (with EQ and the amp's EQ) and it also helps to have a tube amp (Like I said in the other thread, not sure if you can get that tone with your hybrid.)
Growl sound on Paranoid
- Cryptic Night
- TheMrAxeman
Re: Growl sound on Paranoid
thanks this helps alot
