finally an update
Have had some problems along the way.......
The laminate I did for the headstock was to thick so the machine heads wouldn't go through far enough and after sanding it down to the point where they were long enough the wood was to thin and had the potential to snap very easily so what to do.....METAL
now I just have to make sure it isn't sharp so the kids don't severe a limb
next problem was how easily basswood dents
...I spend ages sanding it nice a smooth just for it to get a dent when I sat it on a rough saw horse. So I ended up having to primer it early to harden the surface (worked a treat)
obviously some filling has had to happen after the priming so hopefully it holds in there
now that it has metal on the headstock I am going to have a metal plate where the strings go through the body (that will be painted the same colour as the guitar)
hopefully I can get it painted next weekend to give it a chance to dry for the tronfest....but that is pushing it a bit
