Coil Splitting
Coil Splitting
Does anyone here know if I could coil split a 2 conductor/wire pickup somehow? I wouldn't connect it to any tone knobs, just volume so I dont know if that makes any difference?
Thanks
Thanks
Re: Coil Splitting
I don't believe it is possible to split a 2 conductor pickup since both magnets are wired with one wire.BowTie29 wrote:Does anyone here know if I could coil split a 2 conductor/wire pickup somehow? I wouldn't connect it to any tone knobs, just volume so I dont know if that makes any difference?
Thanks
Re: Coil Splitting
if it's a humbucker, then yes, it can be converted, but it's tricky.
Re: Coil Splitting
Haha, I searched and read some stuff but just was seeing if anyone here had any experience or their own knowledge on this
Re: Coil Splitting
it can be done but if you have to ask the question then it probably isn't something you should try and do....don't wanna sound like a dick but it is true
Re: Coil Splitting
if it's a humbucker, then it's only 1 magnetdannyahansen wrote:I don't believe it is possible to split a 2 conductor pickup since both magnets are wired with one wire.
basically, you have 2 coils, both wrapped with an awful
lot of copper wire. Both coils have a start and an end.
Let's call them A, B, C and D. Then you have the grounding
wire that's connected to the baseplate.
Now, in the construction as a whole, you could say that
A and D are the start/end of the pickup, whereas B and C
are soldered together(lift the tape around the pickup and you'll
see for yourself
break the connection between B/C and lengthen each wire and BAM...
...you have a 4 conductor pickup
Re: Coil Splitting
BowTie29 wrote:Haha, I searched and read some stuff but just was seeing if anyone here had any experience or their own knowledge on this
Sometimes I can't resist being a smartass!
Re: Coil Splitting
we knowPaul Wolfe wrote:BowTie29 wrote:Haha, I searched and read some stuff but just was seeing if anyone here had any experience or their own knowledge on this
Re: Coil Splitting
Better than being a dumbass, though.
Re: Coil Splitting
Paul Wolfe wrote:Better than being a dumbass, though.
Re: Coil Splitting
What I should have said is "no it can't be done unless you modify it".Stiltzkin wrote:if it's a humbucker, then it's only 1 magnetdannyahansen wrote:I don't believe it is possible to split a 2 conductor pickup since both magnets are wired with one wire.
see for yourself). What you need to do is to remove the tape,
Didn't think most people wanted to actually do that. For me the task is too much of a head ache. I would have just bought a 4 conductor pickup.
Re: Coil Splitting
I probably would toodannyahansen wrote: I would have just bought a 4 conductor pickup.
but really, if you know how to handle a soldering iron(and if you're cheap) it's as easy as
installing a pickup to the pots, controls etc
Re: Coil Splitting
man you're doing a lot of dredging.....are you trying to bring some life bak to the boardStiltzkin wrote:
I probably would too![]()
Re: Coil Splitting
I hope
