Making Fretboard Inlays
Have any of you done your own fretboard inlays? I was thinking of replacing the dots on my V neck with Les Paul Custom style block inlays... is this possible and if so does anyone know how to do it?
Re: Making Fretboard Inlays
It's possible
tricky...but possible
Seeing as most guitarbrands use 'Mother of Pearl' for their inlays,
maybe you should start there?
Then it's just a matter of PRECISE cutting and superglue and VOILA
I have done it when the fretboard is already attached and it is very tricky because you need to get the new inlays perfectly level with the board which means getting the original routing out of the board perfect within millimetres...because it is really hard to sand the new inlays level with the frets in
you would be best off getting pre cut inlays ( http://www.stewmac.com/shop/Inlay,_pear ... _Sets.html ) then at least they will be nearly perfectly shaped where as if you cut them yourself its just something else to go wrong
then trace around them on the board and buzz out the wood. Again getting depth exact is tough but not impossible
I would be tempted to just go for stickers ( http://www.inlaystickers.com/servlet/th ... ers/Detail ) .....I have put some on a couple of guitars and yes can feel them a little (mainly if you have small frets) but it isn't annoying
How do you remove the wood?sytharnia wrote:then trace around them on the board and buzz out the wood
I use a good old fashioned chisel when I did it but you could use a router (although not recommended unless you are really really good with it) or a dremel http://www.testntools.co.nz/dremel-300- ... 30482.htmlPaul Wolfe wrote:How do you remove the wood?sytharnia wrote:then trace around them on the board and buzz out the wood
Yeah, I have a good Dremel set, but I can see easily destroying the neck with it! f I decide to go through with it, I'll by the inlays from StewMac and use a chisel.
Thanks for the advize
its a lot easier using a chisel with rosewood to....maple is a pain, when I scalloped my maple board it took 3 x as long as when I did the rosewoodPaul Wolfe wrote:use a chisel.
If you decided to refret the V at the same time it would make doing the inlays a fare bit easier from a sanding/leveling point
I may refret the V... it doesn't need it, but I've been watching Dan Erlewine's refretting DVD and I'd like to try it. Of course it all is on hold 'til I find a job. I disassembled the V and it's just sitting because I can't afford the supplies for the refinishing.
The Squire Strat in the other post had tremendous buzzing on a couple frets, but I couldn't get the truss rod to budge, so I traded it in on another Strat... this one in in decent condition although I'm thinking the mirrored pickguard has to go!
